Cylinder head bolts help
hi, im new to the civic scene and was wondering how tight i need my head bolts to get
I keep tightening the bolts and when it finally gets tight, it keeps spinning. How do i know when they are tight? All of them get to that tight point then just spin free. 1995 Civic Thanks in advance James |
RE: Cylinder head bolts help
call auto zone and ask for a head bolt tighting seq and they can print it off where u from
are they the right head bolts
i got them from the dealer, they look the same size
get a haynes or chilton. they should have torque specs.
The head bolts are mad to strech that is why it just keeps going. you need the right torque sequence and spec on them. If you have tightened them down once and did it wrong my recommendation is to get another set and do it right. You can get but with doing it again as long as you didnt over strech them. Good luck.
