d15b block d16z6 head
Old Aug 22, 2007 | 12:50 PM
DreamTeam87's Avatar
Default d15b block d16z6 head
I have a d15b block with a d16z6 head.... i recently changed the pistons and order d16z6 pistons... when i put them in they were too big... not inbore but in lenght... so i had to put 3 head gaskets to make them fit.. now they are wearing out and i wanna put the right pistons in... so arent the d15 and d16 pistons sopose to be the same or are this company just screwed up?
Old Aug 22, 2007 | 02:39 PM
PhilStubbs's Avatar
Default RE: d15b block d16z6 head
no, the pistons are different.
how did you make the engine run with 3 headgaskets. thats crazy
Old Aug 23, 2007 | 12:58 PM
i dont know i just added extra pounds of torque... the compress was 230 the pistons cameout the block like a cm...but its starting to wear the gaskets out....
Old Aug 23, 2007 | 02:51 PM
PhilStubbs's Avatar
was it a stackable headgaket for setting compression?
Old Aug 23, 2007 | 05:49 PM
naaa
Old Aug 23, 2007 | 06:10 PM
are the d15b and d16z6 the same size pistons in lenght? cause everywhere i look it says they are but i order d16z6 piston and they were to big
Old Aug 23, 2007 | 06:14 PM
am i better off keepin the d15b block wid d16z6 heador d16z6 block and head?
Old Aug 23, 2007 | 06:16 PM
ef4life's Avatar
first off, you don't have a d16z6 block, so a d16z6 piston will not work.
you need to use a compression calculator and figure out which piston you need for your setup, and the goals for your engine. basically you use this calculator to figure out which pistons you need to fit in your engine and give you the desired compression ratio.
stacking 3 headgaskets is retarded. if your pistons didn't fit properly you shouldn't have run the enigne.
and why did you replace the pistons anyway? they usually don't go bad and need to be replaced
Old Aug 24, 2007 | 02:39 AM
PhilStubbs's Avatar
yes, you would be better off with a z6 block
vtecaddict
Jun 1, 2009 09:06 AM
jo7man4
Jan 27, 2007 01:13 PM
F23AccordLX
Apr 22, 2006 10:14 AM
B20B_Hatchback
Aug 26, 2005 06:40 PM
Zenkis15
Mar 16, 2005 09:03 AM
