d15b internal question
Old Oct 25, 2006 | 11:37 AM
roblinxs011087's Avatar
Default d15b internal question
ok so i'm going to swap out my little old d15b7 for the jdm d15b, but ive been doing some research and only been able to find parts for the d16. so my question is would arp headstuds fit the d15 if they were meant for the d16. also would most of the internals be interchangeable between them or would i need to find specific d15b parts?? any help would be appreciated.
Old Oct 25, 2006 | 02:40 PM
WhtRice's Avatar
Member
Default RE: d15b internal question
i'm pretty sure that the headstuds are different because ARP's headstuds for the d16s differ so right off the bat you have Z6,Y7,Y8 headsuds that are all different part numbers, what are the odds that you'll pick one of the different 3 and choose the matching one? i'd give the tech line a call i'm pretty sure they have d15 headstuds theyll sell over the phone, worth a try.[&:]
Old Oct 25, 2006 | 04:57 PM
t34me's Avatar
^^^ No
I have a JDM D15B with D16Z6 ARP bolts in the head. Same cast.
Old Oct 25, 2006 | 08:49 PM
riceburner700's Avatar
z6 headstuds should work just fine
Old Oct 25, 2006 | 09:37 PM
J50CRX's Avatar
should do!
Old Oct 26, 2006 | 04:26 PM
ok then i am looking into beefing up internals as to lower cr heads and lighter connecting rods. soo anyone have a list?? also seeing how u have the same motor t34me tell me did u keep ure a/c ?? and what kinda turbokit r u running
Old Oct 26, 2006 | 04:43 PM
Remmy's Avatar
Here is my list to give you an idea.
B16A block
Wiseco Turbo Pistons, coated skirts
IB Spec H beam Rods
Balanced & Polished Crank
All Honda Bearings
2x blueprinted
New rear main seal
New Type-R oil Pump
New Type-R water Pump
Diamond Bore and Hone
Block guard
Thats for a full bottom end makeover
Old Oct 26, 2006 | 08:13 PM
t34me's Avatar
Well, last turbo kept ac, but becuause this is internally wastegated, it set the turbo back and the intake would not clear the block, so i had to flip the compressor around, so the AC had to go. But, as you can see in the pic, i lost some weight, and now i have all the room in the world to work. Im running a Garrett T3 .42AR
Old Oct 26, 2006 | 11:05 PM
so did u have to make a shopping list or was it a bolt on kinda deal. also seeing that i want to run a greddy kit. and if i do get the kit would i be able to just change out snails or would i have to get a new turbo manifold .
Old Oct 26, 2006 | 11:12 PM
t34me's Avatar
I researched a lot about the components, and pieced it together from there. Im not sure what turbo comes with the greddy kit, but i imagine you could just swap out whatever turbo it is with the upgraded version(ex.. if the greddy comes with a T3 .42 AR, you could take it off and buy a T3 .54 AR, you get the idea) BUT, if you want to save some serious cash, youll put the kit together yourself, and not buy the greddy
