D15B JDM Spec?
Honda civic forum...
this is a question that I know about ten of you can answer without thinking. so i will ask it cause i don't know to much on the subject. D15b JDM Spec... this guy http://www.hmotorsonline.com/shop/sc...age&item=30021 My friend wants to drop it in his crx. Multiport is already wired. He currently has a DOHC zc with a DX or Si transmission (ef cable) I still need to know about a couple things 1. Transmission? will his current transmission bolt up? 2. ECU? which is the best one to use/easiest to wire up? 3. Wiring? can we use his excising wire harness? any information will help me.. if some one can just lay down...what i need, that would be hella cool. |
Alright..found out i can use the existing transmission.
1 down 2 to go |
2. use a P28
3. use existing harness, get OBD0-OBD1 ECU conversion harness, and distributor conversion harness. Both can be found on Phearable.net I believe the above is correct. |
that was exactly what i was looking for...
thank you. |
