D15B2_how much HP_62 or 102?
Old Jan 22, 2008 | 07:42 PM
fiddlinmax's Avatar
Default D15B2_how much HP_62 or 102?
Found my engine type for my '89 Civic HB on the list. Thanksto whomeverputting that list there. Here is the description:
D15B/1/2/7 1.5L SOHC non-VTEC '88-'95 Civic's 62-102hp
That is a pretty wide range, and makes me wonder how much horsepowermy engine actually has. Sure seems like 62! Slower than moleasses. Can anyone explain how to determine a more accurate estimate?
Old Jan 22, 2008 | 08:04 PM
magic_mohawk's Avatar
Default RE: D15B2_how much HP_62 or 102?
The D15B2 has 70 to the crank if I remember. I had one in my hatch before I swapped.
Old Jan 23, 2008 | 02:44 AM
jamned's Avatar
Found on wikipedia:
D15B1 (Same as the D15B2 engine, but with a mild camshaft, and a restrictor plate between the throttle body and intake header) [ul][*]Found in: [ul][*]1988-1991 Honda Civic Hatchback [ul][*]Displacement: 1493 cm³[*]Bore and stroke: 75 mm X 84.5 mm[*]Compression: 9.2:1[*]Power: 70hp (52kW) @ 4500 rpm & 83 ft·lbf @ 3000 rpm[*]Valvetrain: SOHC (4 valves per cylinder)[*]Fuel Control: OBD-O DPFI[/ul][/ul] [/ul]You could verify this by opening up your hood and looking for an "Engine no." stamped plate in your engine bay. It should be somewhere near the front of the engine bay, on top of where the radiator is.
Old Jan 23, 2008 | 04:09 AM
My04Civic's Avatar
Administrator
yeah, around 70 or so horses sounds about right, wikipedia pretty much never lets me down either.
Old Jan 23, 2008 | 06:33 AM
Lost's Avatar
wow thats like 55 to the wheels
Old Jan 23, 2008 | 05:00 PM
jamned's Avatar
I have a carbureted 87 civic with a D15a2 that gets around 70 to the wheels...BUT for 4-5 years, I drove it around with really clogged valves and retarded timing, so it was probably around 40 hp at the crank. I just remember after I rebuilt the car, my friend was assuring me that I doubled my hp by cleaning the valves.
Old Jan 23, 2008 | 05:16 PM
Lost's Avatar
crazy, ya when you get an engine that old carbon can really rob power
Puchki
Aug 11, 2011 08:43 AM
White_Devil
Dec 5, 2004 03:04 PM
White_Devil
Oct 28, 2004 02:39 PM
dalifts
Sep 16, 2004 07:44 PM
Rice Tumbler
Aug 11, 2004 09:06 PM
