d15b7 buildup
i have a 93 civic lx with a d15b7/5 speed tranny. What i want to do is swap head to 1.6 vtec and rebuild entire motor with new cam and run boost and maybe sum nos. right now i have the turbo kit and engine rebuild kit. So my question is what head do i need to get for swap, forged or regular pistons, and what kind of cam should i put in.
ORIGINAL: Nail I3unny
some a1 pistons will put you at a sweet 12:1 compression ratio.
For just the a turbo set up OEM cast pistons/rods will get you to about 200-250whp safely. Above that you'll need forged both. I'm not a fan of nitrous so I wouldn't know what to tell you about that. For the head, the D16Z6 is easiest to use and it works well. For the cam maybe contact Akmee.
idk about on a d15 but on a d16y8 you can run 7-8 psi safely no more than that though. and i have never seen it but someone was talking about spraying the nitrous straight into the turbo idk if you can do that or not though. if you boost i wouldnt spray
ORIGINAL: Kedawei
Think you got the wrong thread there. He's turbocharging, and A1 pistsons in a D15 yield a static compression ratio of about 10.5:1 (D16 = 12:1).
