HondaCivicForum.com
-   Engine & Internal (https://www.hondacivicforum.com/forum/engine-internal-11/)
-   -   D15B7 shaking on low rpms (https://www.hondacivicforum.com/forum/engine-internal-11/d15b7-shaking-low-rpms-95836/)
Stefanov191 Sep 19, 2013 05:58 PM
Hi to all. I have 95 civic 4dr with d15b7 on it. A few days ago the engine started shaking between 1000-3000 rpm but only when get warmed, when is still cold runs great. Today i took out the spark wires and the holes for the spark plugs were all in oil, which means i need new valve cover gasket, now is with silicone on it and obviously is bad. I bought new 4 spark plugs NJK-R and replaced the old ones, but no success. So where i should to look up for a problem, wires, coil, distributor, lambda sensor and etc. There are so many things who could be the reason for this so every help and advices are appreciate.
itburnswhenIP Oct 8, 2013 02:57 PM
could be the injectors try adding some Seafoam injector cleaner and se if that helps. also clean out your IACV.
