d16 spudders
my 94 civic d16 spudders on acceleration when warm...generally in second right after changing gears but it does it in all gears as well as an occasional spudder while just revving. i got new plugs and wires, timing adjustment, a new fuel filter, new air filter, oil change...but it still spudders. anybody??
RE: d16 spudders
How many miles? Might want to consider running some Seafoam through it.
Also, where are you shifting (rpms)? |
RE: d16 spudders
I had a similar problem once and it turned out to be my coil and plug wires.
RE: d16 spudders
Like tony said, try seafoam, I always try the most inexpensive solution first.
RE: d16 spudders
ORIGINAL: Pete Like tony said, try seafoam, I always try the most inexpensive solution first. |
RE: d16 spudders
when are u shifting it is the most inportant and cheapest question. and cause if u go into second at 20 kmph and then shift too 3rd at like 30 kmph your car is gunna shake
