D16y7
Ok i have a D16y7 sohc (about 106 stock)there is alot of talk about people doing swaps and boosting and just boosting their d-series engines...I was wondering if it would be better for me to either stick with the d16y7 and boost it, or for me to do a swap like a b16 or b18 and thenboost??
RE: D16y7
you can boost it but i had a friend boost his and it blew when tuning it. He got it fixed and it goes fine now.
Either swapping or boosting will both give you what you want. But if i was you go with the b18c |
RE: D16y7
I boosted a Y7 for a good while, it did blow but because I was at the track and upped my boost to 18psi butdid not put my 18psi tune on my ecu. It's a ok engine but I suggest a Y8 intake manifold and a 96-00 ex transmission for starters
RE: D16y7
^ What Marty said.
D series are no more suseptable to "blowing" than any other motor. Most people will tell you to mini me, but your head is fine with a port. The only head worth using unported is a Z6. |
RE: D16y7
first mod should be a 96-00 ex transmission, then intake manifold and intake.
RE: D16y7
BUMP
Will an intake manifold from a Y8 bolt up to my Y7 Head. I don't want to do the Mini swap, I would prefer to just do the intake manifold and work from there. What do I do for a throttle cable? |
RE: D16y7
ORIGINAL: kennmonster BUMP Will an intake manifold from a Y8 bolt up to my Y7 Head. I don't want to do the Mini swap, I would prefer to just do the intake manifold and work from there. What do I do for a throttle cable? a mini-me swap can be quite rewarding... bolt-on 25hp. |
RE: D16y7
ORIGINAL: trustdestruction ORIGINAL: kennmonster BUMP Will an intake manifold from a Y8 bolt up to my Y7 Head. I don't want to do the Mini swap, I would prefer to just do the intake manifold and work from there. What do I do for a throttle cable? a mini-me swap can be quite rewarding... bolt-on 25hp. |
