D16Y8 build-up
Old Feb 2, 2005 | 03:31 PM
grncivicvtec's Avatar
Default D16Y8 build-up
Yeah I am going to build on my sohc vtec, another ? what should I do with it for now all motor. Were should I start. And how much is it going to cost, I was think crower cam, runs about $350. but what else?
Old Feb 2, 2005 | 09:50 PM
blackeyes's Avatar
Default RE: D16Y8 build-up
blox and skunk2 make the best cams for honda, my opinion, and toda (expensive as hell). but get some hc pistons, upgrade the valvtrain, intake manifold, throttle body, and am ecu, and ull have a n/a sohc beast.
blox cams around 550
cam gears 200 or less
itantake manifold, 270 (how much i got mine for)
tb maybe 400 or less
vlavetrain 200
ecu 300.
dont know about the pistons though.
Old Feb 2, 2005 | 11:21 PM
sacicons's Avatar
itll be a lot less for a d-series. and i dont think blox has released the sohc cam yet. but when they do, ill see if i can get a group buy.
Old Feb 3, 2005 | 09:09 AM
Remmy's Avatar
sacicons, I looked, i gotta d16y8. Just curious.... are they tough engines? I heard they can take a serious beating. And are they strong enough to handle a s/c ?
Old Feb 3, 2005 | 09:44 AM
hondabboy's Avatar
yo tell you the truth most sohc can got with a beating depending how you beat it for about a year. i had a friend running sohc all motor and was spraying 100 and it lasted for a year. soo yeh.....i say the way you treat your baby.
Old Feb 3, 2005 | 04:52 PM
Remmy's Avatar
my baby has 64000 miles on it. Works excellent other than the rattling heat shield of the manifold [:@] [:@] [:@] [:@] [:@] GOD I HATE THAT NOISE! NOBODY WILL CLEARLY TELL ME HOW TO REMOVE IT EITHER!
Old Feb 3, 2005 | 06:21 PM
ohbiskits's Avatar
the heat shield is held on by 4 bolts...just remover the 4 bolts and it will come right off
. i think if your looking directly at the heat sheild thats where the bolts are...its been a while since i
took mine off ...in a Y pattern...2 on top 1 in middle and 1 in middle bottom
Old Feb 3, 2005 | 08:29 PM
sacicons's Avatar
yeah, itll handle an SC, if its installed and maintained right.
Old Feb 4, 2005 | 10:32 AM
Remmy's Avatar
I know Im an idiot. but where is the heat shield. This is my first front wheel so the engine is a little bit different. If someone could show me the light ill be fine.
[IMG]local://upfiles/1537/9EAB6385B9C343488FBF85FCBFABC74E.jpg[/IMG]
[IMG]local://upfiles/1537/64C3A94FFFF240C0BAEB21837EF0D0EC.jpg[/IMG]
Old Feb 4, 2005 | 02:17 PM
tonguetwiztid's Avatar
here ya go
[IMG]local://upfiles/1604/DA9B6222761349348C440081AEF6CC99.jpg[/IMG]
