Determining redline
Always have been curious how car manufacturers determine the redline of an engine. And wouldn't it change based on modifications made to it such as new pistons.
RE: Determining redline
I think the head has more to do with the redline than the bottom end.
Why over-engineer the bottom end when the topcan only go so high?
usually when the engine wont make any more power and the curve drops off they plop the redline a few hundred RPM in front of the drop.
a lot of it also has to do with what the engine can take |
ORIGINAL: Nail I3unny a lot of it also has to do with what the engine can take |
Calculus.
Care to elaborate?
its alot of factors, but obviously reliability is huge for a honda. there are things like rod to stroke ratio, hp @ rpm's, basicaly there is really no real formula to figure redline on an engine its going to be different for every engine because of its design and limitations, also its uses
ORIGINAL: Mr Mobsta Man Care to elaborate? Basically, all the sciences that you can think of to determine the strength of parts, and the stresses that would applied on them within an engine,all revert back to calculus for calculation. :edit: That's not to say engineers go back and calculate every possible variable for every single moving component in an engine that could cause stress or failure at a given rpm, or maybe they do I'm not an automotive engineer. But I assume like most things with experience you get good at what you do, and can determine at least general limitations quickly. |
Yea I was just curious. I knew redline was around where the engine got maximum power, but I figured that would not be the most accurate method in determining where to place the actual redline mark, and the associated rev limiter as well.
