diy hp gainers?
is there any at home horse power gainers or anything you can do on a budget to make some more ponies?
RE: diy hp gainers?
i have heard of more grounds and wrapping the fuel lines in insulation to prevent them from getting hot. is there any little mods that can be done to make budget horsepower???
RE: diy hp gainers?
timing advance does a little ,bettr air filter, helps a bit.
RE: diy hp gainers?
well there is throttle bodies or intake manifold. They are ez-erdiy jobs. I do know u have to drain the anti-freeze with the intake manifold so i would read on it a little bit.
RE: diy hp gainers?
nitrous, I/H/E
RE: diy hp gainers?
ORIGINAL: jc6711 nitrous, I/H/E as for the question: advance timimg clean filter replace all fluids (if you have extra laying around) i.e. brake fluid, tranny fluid, etc. heat wrap intake/exhaust components clean engine (doesn't really help unless it's covered in grease and debris) adjust tire pressure for whatever you use the car for (ex. auto-x, drag, etc.) diy toe adjustment (there's another thread on how to check) adjust camber if possible (more tread) remove unneeded items in car (trash, anything that weighs a lot and usually doesn't go in a car, for example, your fatass! lol) and simply drive the car when it's alittle colder. |
RE: diy hp gainers?
Its a Civic, they don't even respond that well to basic stuff like IHE, so don't expect much difference with the stuff mentoined above. THe only one that'll really do you good is weight reduction, but once you get too far into that, you start sacrificing comfort.
RE: diy hp gainers?
Weigth Reduction FTW! Gut your interior and drop the A/C System. Buy about 20 lbs of dry ice and get rid of all that nasty sound deadening tar. Buy a crappy plastic seat for $50 but only ways 10lbs. All depends on how far ya wanna go.
RE: diy hp gainers?
so weight loss is wanna the best ways to go? i have an intake, header, full exhaust and a vafc. i appreciate the help. is there truth in more ground wires freeing up horses? and insulating fuel lines?
RE: diy hp gainers?
Yea IMO Weight Reduction is one of the best ways. I wouldnt say more ground wires but better quality ground wires. Not really a DIY cause Youd have to go out and by a nice grounding kit
