do i need new engine
hiya i was wondering if anybody can help me please
my p reg civic is eating lots of oil i have no leaks the underside of the oil cap is a tan colour and have light blue smoke coming from exuast other than that it runs perfectly the engine is very quiet i love my car !!!! 740000 on the clock i,ve been told a new engine is needed could it not be somthing more simple angie. sorry i had added an extra 0 on my millage its only 74000 miles. thanks to all who have replied so it looks like a new engine after all ! |
RE: do i need new engine
ok how many mile on the car cause what i got from that was 740,000 mile i belive in honda but thats alot . sounds like it could be rings and what year car is it.
run a compreesion test and see how the cylinders are doing.
or do a leakdown test or also try a wet compression test
Yea, you need rebuild. A new engine will cost much less.
ORIGINAL: Pete run a compreesion test and see how the cylinders are doing. |
hiya its got 74000 miles on clock and 1998 is the year'
i would nt know how to do a compression test unfortunally i would have to put it into a garage then were talking big bucks so a new engine would prob be the answer for me ? angie. |
More than likely your piston rings are worn. You'll need either a rebuild or a new engine. If you can track down a cheap enough engine, that may come out cheaper. Get quotes on a rebuild to be sure though.
Compression test blows head gasket??!
"If he did a compression test at that amount of milage he would more then likely blow the head gasket"
How would running a compression test blow the head gasket? When a cylinder compresses there is X pressure. When a cylinder compresses and there is combustion, there is a lot more than just X pressure, right? I am asking because I am trying to figure out how to do a compression test on my 91 hatchback. The channels to the spark plugs are so long, are there compression gages which are made to accomodate this? |
