Does The ZC Vtec = D16Z6?
Old Sep 14, 2005 | 10:02 PM
93SiHb's Avatar
Default Does The ZC Vtec = D16Z6?
My Engine is starting to give with all the recent head problems and me driving it about 600 miles a week having problmes starting it ive been to the local engine places where they sell jap engines and when i asked for the d16z6 they told me the zc was it in (jdm) im new to the import scene so i dont know anything they showed me the engine it was a ZC and had the Vtec valve cover and all that i want to know is this the same engine and putting in all my components will it pass smog
Old Sep 15, 2005 | 04:08 PM
Kappa22's Avatar
Default RE: Does The ZC Vtec = D16Z6?
It's not the same, but it'll work. Some of the brackets are different, and off the top of my head, I think it either has one more or one less sensor. Also, being from Japan, it packs a bit more punch. And yes, it will pass smog.
Old Sep 15, 2005 | 11:10 PM
93SiHb's Avatar
which brackets wouldnt work if you remember
Old Sep 16, 2005 | 11:46 AM
Kappa22's Avatar
Well, if I recall, the jdm power steering bracket doesn't fit the USDM pump or something like that (and I think the A/C bracket too, if you have it). All the bracket bolt holes on the block are the same, so you just have to switch them. The best thing to do is just swap all your original brackets onto the ZC. That will make sure everything works.
Old Sep 16, 2005 | 05:05 PM
93SiHb's Avatar
ty i appreciate your responce
Old Sep 19, 2005 | 12:00 AM
93SiHb's Avatar
ok a few more questions which do you think would be the better swap the Zc or the original what i have now im really considering the zc and if i go with it would i have to swap my distributor in there? also is the water pump and timing belt the same as the D16Z6?
Old Sep 20, 2005 | 08:12 AM
93SiHb's Avatar
Basically all i wanna know is are the ZC parts the same as the D16z6 such as water pump timing belt spark plugs
Old Sep 20, 2005 | 12:22 PM
Kappa22's Avatar
Here's the part numbers and/or what they come off of.
Alternator Belt
31110-PM5-305
88-91 CRX Si
A/C Belt
38920-PM5-A04
88-91 CRX Si
RT Engine Mount
50805-SH3-040
88-91 CRX Si
LT Engine Mount
50821-SH3-040
88-91 CRX Si
Frt Engine Mount
50840-SH3-000
88-91 CRX Si
RR Engine Mount
50810-SH3-040
88-91 CRX Si
Thermostat
19300-PM3-003
88-91 CRX Si
Thermostat Gasket
19308-PJ7-000
88-91 CRX Si
Water Pump
19200-P01-004
88-91 CRX Si
Oil Pan Gasket
11251-P01-004
88-91 CRX Si
Lower Radiator Hose
19502-PM3-000
Crank Seal
91212-PE0-662
1989 Integra
RR Main Seal
91214-PH1-013
1989 Integra
Cam Seals
91203-PG6-013
1989 Integra
H/C Cover Gasket
12341-PM7-000
1989 Integra
Dist Cap
30102-PM7-016
1989 Integra
Dist Rotor
30103-PM5-A05
1989 Integra
Ex Manifold Gasket
18110-PG6-003
1989 Integra
Intake Gasket
17105-PG6-s00
1989 Integra
Head Gasket
12251-PM7-003
1989 Integra
Timing Belt
1988 Prelude 2.0
Old Sep 20, 2005 | 11:53 PM
93SiHb's Avatar
are you thinking of the DOCH ZC?
Old Sep 21, 2005 | 11:40 AM
Kappa22's Avatar
F**k. Sorry about that. I wasn't thinking. I've only done DOHC ZC swaps in my 4Gs, so that's what I'm used to working with. I'll try to find the SOHC list. I think some are the same though.
