ECU HELP! :/
ok im planning on getting a 92-95 LS motor (OBD1)
on my Civic HB DX will the LS plug n play to my P06 ECU?? since ther both obd1s |
RE: ECU HELP! :/
there's more to it than simply obd1, are both engines (or either) vtec, auto or man trans, your best option is to use the ecu for the motor, you should always get the ecu when you get the motor when doing a swap
