Edelbrock TB and IM
hey guys...i'm looking into both the TB and IM from Edelbrock...what performance gains would i be expecting from this product? also is it a good idea to upgrade these two products on my car for getting the ultimate gain from my H/I/E? I am running with an AEM CAI and i'm waiting on my ApexiWS2 and I have a Megan Header that i'm waiting to install with my exhaust, so i just thought why not do both the TB and IM at the same time...what do you guys think? Anyone running with Edelbrock TB and IM? thanks!
RE: Edelbrock TB and IM
What engine is this on? As for the TB how big are you going, cause if you go too big it can hurt. <- wow that sounds bad.
tb and im from edelbrock, you can never go wrong with that. i would say if you plan on going FI in the future then these are great buys.
clarification on FI? still pickin up on the terms! I'm not too sure which TB size i should go with...stock is i believe 56mm on my engine...how big can i go to ensure that my AEM CAI will still fit? or does that even apply?
ORIGINAL: tha_next_Kobe clarification on FI? still pickin up on the terms! I'm not too sure which TB size i should go with...stock is i believe 56mm on my engine...how big can i go to ensure that my AEM CAI will still fit? or does that even apply? TB = Throttle Body IM = Intake Manifold TB bore depends on what you plan to do in the future (ie turbo, na) |
thanks ej6...i will most likely be turboing my ride...not this summer because i won't have enough cash flow because of university in the fall again but it will be tuboed...would 65mm TB be good enough?
what engine do you have in your car? also if you plan on turbo, you might just wanna send that header back cause you can't use a header with a turbo.
it's a d16y8...i'd like to push around 200hp with everything done to it...i think that'd be respectable...i didn't know you couldn't run a header with a turbo...does the turbo kit come with one? or how does that work?
You can make 200 without the expense of an aftermarketIM/TB.
ORIGINAL: tha_next_Kobe it's a d16y8...i'd like to push around 200hp with everything done to it...i think that'd be respectable...i didn't know you couldn't run a header with a turbo...does the turbo kit come with one? or how does that work? |
