engine build compression q?
Old Apr 18, 2008 | 12:32 AM
rcalimquim's Avatar
Default engine build compression q?
ok, i got a turbo d16, planning on rebuilding the engine now since im boost and if i go with a higher compression will i be making more power at the same level of boost im using?
Old Apr 18, 2008 | 06:19 AM
AgentofDarkness's Avatar
Default RE: engine build compression q?
Usually if you rebuild the engine and want to run a turbo, you want low compression. If you run high compression, you can only run low boost. If you run a low compression, you can run a higher boost. High compression means that the temp/pressure in the cylinders will increase. High Compression = N/A engine, Low Compression = Forced Induction
Old Apr 18, 2008 | 04:15 PM
sacicons's Avatar
go for about 9.0-9.5:1. that will give you enough room that a good tuner can get it running well with a decent amount of boost, without it being too low and taking away all of your off-boost power.
DjHagios
Sep 29, 2009 07:58 PM
turbo speeder
Jan 28, 2009 03:57 PM
SovXietday
Feb 12, 2007 11:55 PM
vlaladim
Oct 9, 2006 08:32 AM
nachoman
May 23, 2005 02:37 PM
