Engine Build Questions
Fist off is 10:0:1 compression too high for boost? Second I'm buying some new parts for the swap like water pump, timing belt and so on, but do I need to worry about the alternator & the distributor, or can I leave the old ones on and be okay?
Thanks |
RE: Engine Build Questions
no its not to high...theres an integra out there on streetfire running 11.5:1 CR with 12 psi of boost out of a roots supercharger. i would recommend getting lower comp pistons when you start tearing into the bottom end tho.
ok thanks mang, and what about the distributor and alternator ?
what about them?
is there a need to replace them on a used engine? Iv heard i should get the alternator tested, but should i just buy new alt and distributor?
how many miles are on them?
if there is nothing wrong with them then don't replace them, but i would get a new cap, rotor, and stuff for the dizzy.
and yeah 10:1 is about as high as i would ever go for boost, most people usually run about 8.5-9:1 compression for boost. |
ok cool thanks guys, about 40k miles on the engine
what engine management are u goin to be using?
