engine burn out
Can anyone tell me how long a 1999 1.6 vtec engine can take being in the red on the heat gauge without causing any engine damage? My civic got a hole in radiator and temp went into the red before i realised, only for a couple of min then i stopped. engine sounds fine now thou??? any help would be great
[IMG]local://upfiles/2935/C7A2048720DF44188E9C9632627A708B.jpg[/IMG] |
RE: engine burn out
keep coolant in it. if it has a problem, it will show itself soon in burning coolant or rough idle.
RE: engine burn out
Thanks ill keep an eye on it! Its booked into honda to have a new radiator fitted £260 aint that bad is it?
RE: engine burn out
I don't think a few minutes would hurt it too bad......you might get lucky.
RE: engine burn out
if you let it run once, the new radiator is fitted, you shall see if the engine has been damaged, as you will get steam out your exhaust if the cyclinder head gasket went.
RE: engine burn out
gettin it bk in a few hours so ill tell you very soon
