engine oil leak?
well, today i was just doing the usual fluid checks and such, and i noticed there was a bit of oil wetness around the oil top off, and on the side like it had dripped down, there was not alot of it, barely could tell it was oil until i wiped it, it was just like a moist looking spot. Im not sure if its been there since the oil was changed, but what kind of things should i look for?, or is this nothing to worry about, i havent seen any leaks under the car on the garage floor.
RE: engine oil leak?
i would replace the oil cap & see if it stops
