engine problem need help fast
Old Mar 19, 2007 | 08:34 PM
sloppyshawn's Avatar
Default engine problem need help fast
when i start my car it cranks but quits when i let go of the ignition. i need this car to make it to work.
Old Mar 20, 2007 | 12:46 AM
xramseyx's Avatar
Default RE: engine problem need help fast
little more info would help... what kind of crank? like slow... or.. try the battery.
Old Mar 20, 2007 | 06:13 AM
it cranks up normally but whne i release the ignition the engine dies out and its not the battery. the battery is good i was thinking it might be the main relay or the ignition switch.
Old Mar 20, 2007 | 11:35 AM
TheMoogly's Avatar
Might not help but maybe make sure the battery is tightly clamped on... my car wasnt starting a while ago until I realized my positive had shaken loose from the battery post... worth a look
Old Mar 20, 2007 | 05:08 PM
xramseyx's Avatar
That happend to me 2 times when i first got my car. positive cable shook loose...
Old Mar 20, 2007 | 05:14 PM
Street Sniper's Avatar
You mean when you let go of the key? Definitely the ignition switch if that's the case. The spring will wear out sometimes.
Old Mar 20, 2007 | 05:53 PM
ignition connector to the inition swith was worn out
we cleaned it and it cranks now.
brinriha
Jan 25, 2008 03:28 PM
boyye
Oct 17, 2006 02:42 PM
joe383
Jul 11, 2006 07:10 PM
89civiclx
Feb 10, 2005 12:50 PM
the_reptilian
Jan 16, 2005 05:15 PM
