engine swap
Old Apr 27, 2007 | 09:53 PM
1999BlackLX's Avatar
Default engine swap
hey guys im new to the forum
anyways iv got a '99 civic lx with a stock engine...
i dont wanna go crazy upgrading my car and the most i want to do is an engine swap for a nice VTEC
i dont know any specific model #'s and stuff like b16b etc. so thats were i hoped u guys could help.
can u guys just help point me into the direction of a nice engine (i do like the Preludes VTEC...190hp and 158lbs tq. but if u guys have any other suggestions by all meens plz post and tell me why its a good idea)
thanks guys
Old Apr 27, 2007 | 10:00 PM
ej6buddy's Avatar
Default RE: engine swap
B series engines are usually easier to swap (if you have a 5/6th gen), and a prelude (H22) engine has a nice power gain, but is rather difficult to swap than the b series. they have 3 different displacements (b series that is) a B16, B18, B20. the b20 doesn't include vtec though.Most B16sare found in si's, and B18's are found in teggies (Ls which is nonvtec, and GSR which is vtec) That's only a few options, there are plenty others with varying power.
Old Apr 27, 2007 | 10:02 PM
yea i kind of wnat the most power i can get out of a swap...seeing how i really wont be doing anything else to improve engine performance like turbo and what not (cept intake and maybe a catback)
Old Apr 27, 2007 | 10:05 PM
ej6buddy's Avatar
H22 will give you the highest performance for a reasonable budget
Old Apr 27, 2007 | 10:17 PM
sounds good...
incase i ever decided to go with forced induction....is the H22 a bad idea?
Old Apr 27, 2007 | 10:21 PM
ej6buddy's Avatar
the h22 swap is rather difficult, but if you research enough and have a good idea about what is included, you shouldn't have a problem, and the h22 is a little larger than the b series blocks and are a tad more beefier and require more modification, but have way more torque, and boost won't be a problem, just like boosting any other motor.
Old Apr 28, 2007 | 12:41 PM
Powermidget's Avatar
if you want some bang for your buck id do a jdm gsr swap...good torque compared to b16, nice top end with the vtec and fits comfortable in your vehicle
Old Apr 28, 2007 | 01:37 PM
Kedawei's Avatar
Don't get a H22 if you want to boost. They can't run forged pistons (unless you sleeve them) because of the expansion rate of their sleeves. The pistons will ruin them.
If I were to boost a B-series it would be a B16. I used to think those motors were worthless, but their cylinder heads and transmissions gearing are great, better than a GSR on both counts, and it is quite a bit cheaper than a GSR. Also, when turbocharging, the greater stroke of the GSR doesn't matter as much. Turbos will make up to and only a certain horsepower (they are rated this way, in HP), because they will only flow a certain amount of air, regardless of the engine they're put on.N/A the stroke definitely makes a difference though.A lot more power can be had out of a GSR or better yet a LS/VTEC N/A.
Anyway, if I were going to boost I'd stick with the D-series. But not a lot of people are into those.
Old Apr 28, 2007 | 02:53 PM
hmmm
thanks guys i think i made a dicesion.....now il just get to it when i feel like it
i think my freind said he found another b16 engine (that or a b18) at Pick-a-Part junkyard in great condish that would only cost me 150-300
and from what i heard these are very very easy to swap (correct?)
Old Apr 28, 2007 | 04:22 PM
Kedawei's Avatar
Good price. Yep, easy swap.
chbulldogs11@msn.com
May 27, 2011 09:05 PM
skibum853
Nov 18, 2007 09:40 AM
badboy4life
Sep 1, 2007 08:28 AM
Kingzlei
May 5, 2007 04:06 AM
silvr63vet
Dec 4, 2006 03:55 PM
