Engine Swap Questions
Old Jun 5, 2007 | 04:54 PM
BigBruceBaker's Avatar
Default Engine Swap Questions
I have a 95 ex and was wondering what the best engine was to swap in. I was thinkin along the lines of a B18C and a very possible turbo set up in the future. Would this engine be better than a B16a? I didnt know if it was a possible swap if i wanted to turbo. Also would a jdm engine still be fine for boosting becuase of higher compression?
Any help would be greatly appreciated.
Old Jun 5, 2007 | 05:04 PM
Default RE: Engine Swap Questions
Oh and just to clarify i do want a v-tec. No reason not to. I know i need the tranny and most like an ecu i was just wondering which one would be better for boosting and a minimal amount of custom modifications. I would like their to be no custom modifications but whatever
Old Jun 5, 2007 | 07:07 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
they both have vtec in them and the two engines are very similiar. b18c weighs more than the b16 but it has 10 more hp. you will be able to boost both of these engines and the swap should be a straight drop in. sounds like you need to read up on more info. search about these two engines do see what will suit you the best.
Old Jun 5, 2007 | 07:28 PM
Thanks i posted that then went and did my research haha. I think i might go wit the B18C1 just for the little extra power and IMO its worth the extra money. Thanks for the input
Old Jun 5, 2007 | 07:35 PM
no problem, are you going to do the swap yourself or have a shop do it?
Old Jun 5, 2007 | 07:36 PM
Old Jun 5, 2007 | 07:40 PM
I was thinking of a shop. simply because i have no means to put the engine in. I would like to put the turbo on myself with some help from some buddies that have turbo experience. If i bought a complete turbo kit from GReddy would that be relatively easy to install? I have done engine modifications but never a turbo kit. Also do you know the hp gains wit that greddy turbo kit and the B18C1?
Old Jun 5, 2007 | 07:44 PM
Also sorry i havent had much experience with motor swaps except reading about them. Would they require engine mounts wiring harness? Also it comes with a transmission...the GSR one which i assume would fit the 95 civic ex? Haha these are probably retarded questions...i just figure to come to someone that has personal experience and knowledge
riceburner700's Avatar
b16's have no torque i would go with the bigger b18c1
Old Jun 5, 2007 | 07:46 PM
Thanks man i think i have decided on that with a turbo set up
oldguy
Mar 17, 2007 01:03 PM
PowerWheels86
Feb 11, 2007 08:47 PM
Kunta
Sep 12, 2006 07:24 PM
campbuds
Jul 20, 2006 02:16 PM
Project Si
Jul 16, 2006 06:15 PM
