Expensive Machine Shop Estimate
I got a $2800 estimate on my engine build :(
These are my parts, its being overbored .5mm. 75.5mm Overbored Vitara Pistons Forged I-Beam Connecting Rods with ARP Rod Bolts Crower Stage 2 Turbo Cam Crower Valve Springs Crower Titanium Retainers ARP Headstuds Cometic Headgasket Cam and rear main seals |
RE: Expensive Machine Shop Estimate
I was expecting under 2000, is this place giving me too high of an estimate. They said they will do boring, honing, and balancing. Any input or information will be appreciated, I will be calling around more machine shops.
Just talked to a 2nd shop! I cant believe the difference in this estimate!
$1600 and that includes the boring, balancing, rebuilding the head, and installing all my parts and grinding or polishing the crank I believe he said. He needs the engine out of the car though, how much does a shop usually charge to remove the engine? |
Any suggestions or comments? I am going to keep this thread active over the next few weeks while my car goes to the shop.
ORIGINAL: bcrichguitars Just talked to a 2nd shop! I cant believe the difference in this estimate! $1600 and that includes the boring, balancing, rebuilding the head, and installing all my parts and grinding or polishing the crank I believe he said. He needs the engine out of the car though, how much does a shop usually charge to remove the engine? |
ORIGINAL: inthezoneac ORIGINAL: bcrichguitars Just talked to a 2nd shop! I cant believe the difference in this estimate! $1600 and that includes the boring, balancing, rebuilding the head, and installing all my parts and grinding or polishing the crank I believe he said. He needs the engine out of the car though, how much does a shop usually charge to remove the engine? Car will be in the machine shop in 2 weeks! |
