Fuel Problem
im sick of the i fill my gas tank and in just 1 and a half day it sent half, and i havent used too much i been at least 4 to 5 hours using it. you may think i was racing and messing with it, but the point is that now is spending more fuel than ever before even when i used to race before. what could this be??
RE: Fuel Problem
When was the last time you did a nice thorough tune up?
RE: Fuel Problem
what u mean by thorough tune up? basically what i have done to my car is oil and filter change every 3000 miles, put an intake 6 month ago, and recently timing belt, water pump and tensor 3 month ago, and spark plug wires and spark plugs like 1 year. my car has currently 183,000 miles on a stock engine but intake 2inch pipes and free flow muffler.
RE: Fuel Problem
May have a bad injector. Have you calculated the milage, or doesit just seem like it comsuming more than usual?
RE: Fuel Problem
I think if u dont have a cat on your 2 inch xaust you will consume more gas to.
RE: Fuel Problem
try using some sea foam, change your fuel filter, also do a cap and rotor
RE: Fuel Problem
sea foam?? what that?? what is a cap and rotor??? well anyway my car do have the stock factory cat and is consuming more than usual. some guy told me is the fuel pump but i dont think so my car is does not have any simtoms of that. i think is a injector cause when i push de gas very deep engine drowns in gasoline .
RE: Fuel Problem
distributor cap and the little round rotor behind it
