Gas/Engine Problem?
Old Oct 10, 2008 | 08:35 PM
nitika's Avatar
Default Gas/Engine Problem?
I was driving my 98 Civic today. I drove it about 50 miles to pick up a friend and on the ride home I went to give it a lil gas and it slowly started to slow down...as if the engine wasnt getting any gas. So I tried to give it gas..and it wouldnt go. I ended up pulling over. It acted as though I ran out of gas. But had just had it filled up (and had the oil changed about a month ago). It would turn over but not start. I had to get it towed home. What is wrong. Honda's are suppose to be good cars.
Old Oct 10, 2008 | 11:26 PM
Alright, first of all...
1. Honda's are good cars.
2. If you don't fully maintain your vehicle, no matter who made it, it will have problems once in a while.
Could be fuel filter or possibly something to do with ignition.
Is the engine getting spark?
Old Oct 11, 2008 | 01:27 AM
knoxville's Avatar
yes, they are supposed to be..don't know why people think that, i work in a garage and they tend to have more problems than anything.
_________
Lakewood
Old Oct 11, 2008 | 01:43 AM
nitika's Avatar
hey thanks for ur info guys.
Old Oct 11, 2008 | 02:02 AM
because for some reason some people assume that because it's a honda it doesn't need regular maintenance, and they don't do it and a problem happens
Old Oct 11, 2008 | 05:56 AM
You may have this impression due to the very large number of Civics/Hondas on the road.
OP: If you happen to rule out a problem with fuel (main relay/filter/pump) or spark (coil/ICM), then check whether the timing belt slipped a tooth or two.
Old Oct 11, 2008 | 06:04 AM
also small problems add up to larger problems!!!!
the 2-3things it might be is the fuel pump might have went out-no fuel pressure.
or the coil burned out which is defiantly a weak link on a honda!
or 3 not so common the fuel filter is clogged up and needs changed.
first check for spark. unplug 1 spark plug wire and get a tester for it to ensure it has a spark when cranking. and USE THE TOOL or at least a spark plug on the wire, if you try to just put the wire up to a metal spot and try to spark it it will definatly trash the coil! been there done that to a friends 94civic while doing a compresson test, car even drove ruffly 3-4miles away before the coil completly gave out!
Old Oct 16, 2008 | 06:54 PM
gwl's Avatar
gwl
Maybe you got some bad gas.
edwinss4
Dec 6, 2010 06:10 PM
burgernuds
Nov 6, 2008 06:07 AM
Sprite_15
Nov 6, 2007 04:18 PM
phsballer123
May 4, 2007 07:24 AM
CarmineD187
Jun 12, 2006 10:19 PM
