Gearbox driving me mad!
Hi. I haven't been here in a while but i know theres alot of good people here that are hopefully willing to help me out.
Just had a new clutch put in but now im having a problem with the gears :/ Before Clutch change it was ok, everything was fine even though i needed to replace a few bushes (still not replaced) Every gear it feels like a battle, i come to a stop, try to place it into first and the stick stops halfway, if i bring in to neutral position with a wobble it goes into first alrightish... Feels a bit like its forced. Same goes for every gear whilst driving. Gearbox was replaced with one from an eg. Its driving me mad. When driving it goes in but feels a bit rough. Done a bit of research but couldnt find my problem. Also gearbox was changed due to the synchro going, and this feels different. Hope someone can help. Cheers |
What year do you have by the way?
Does the car go into gear easily when the engine is off? |
Sorry its a 96,but the box was off an eg... Unsure of year.
Feel the same with engine off. Going to be ordering a bush for the linkage. I have a feeling it probably will be that, then get a drive shaft oil seal, then will be getting a clutch slave... Sound alright? |
