go b20b vtec or stay b16a?
havn't been on in a while... so i was wondering if i should go b20b and put my b16a vtec head and obd1 computer or just stay b16a?thanks
RE: go b20b vtec or stay b16a?
i would rather stay b16a. The b20/vtec will break down on you sooner or later. I personally dislike ls/vtec and b20 vtec.
how do you drive your car??
CR/VTEC > B16, build the bottom end and do it
yeah i planed on using a toda racing bore kit, and building the bottem end. i also planned on putting itb's on it.of course sometime rebuilding every thing in the engine. first would be bottem end, then head,then internals(toda racing bore kit), then bolt on's. i think that is planed out well.do you?
dont bore or stroke it just buy a good set of crower rods, weisco pistons, and arp bolt's and studs throughout. Also use honda gaskets throughout.
how come i shouldn't bore it. i would just like a reason. thanks
theres a guy down here with a b20vtec. only thing done to the bottom end is arp rod bolts. 17k miles in 3 years and no breakdowns worth mentionin(ie:due to the combination)
i would rather stay b16a. The b20/vtec will break down on you sooner or later. I personally dislike ls/vtec and b20 vtec. what is wrong with the LS with the V-tec head swap? if you ran into any problems on it let me know cause i am about to swap a LS (V-tec) into my 4 door EG. |
Dude the cyl walls are 3mm thinner or 0.1181 inches thinner. That spread around the whole cyl wall = nothing to worry about really. This is a over hyped myth that is complete bs.
