Got a leak need some help
Old Apr 26, 2007 | 08:44 PM
Skrapdoggydog's Avatar
Default Got a leak need some help
So i noticed a couple spots on the garage floor when I pulled my car out this morning, so i had my friend take a look. Turns out it coming from where the t-fitting (from my oil presure gauge) enters my block. My friend tried to fix itjust by tightening it b/c itwas loose. Didn't work. He then takes the fitting out andlooks at it and itlooks like the threads are starting to strip. I guess the so called "mechanic" who installed it putit in at an angle and f*****up the threads. Any ideas how to fix this without pulling the engine torethreadthe hole?
Old Apr 26, 2007 | 09:56 PM
MY99SI's Avatar
Default RE: Got a leak need some help
tap and die kit... you'll have to tap the hole out a little bit and find a bigger adaptor block to fit since threads will be bigger
Old Apr 26, 2007 | 11:34 PM
riceburner700's Avatar
try not to get any shavings in the block. maybe try some teflon tape
Old Apr 27, 2007 | 07:24 AM
so do i have to pull the motor to install the tap and die kit?
What about form-a-gasket do u guys thinks it will stop the leak if i put it around where the fitting enters the block?
Old Apr 27, 2007 | 07:29 AM
danomatic93's Avatar
June 2010 ROTM
a tap and die kit is not something you install. A tap is a tool that threads or re-threads a hole. A die toll threads or re-threads a bolt.
My suggestion would be to re-tap the hole and re-die the fitting. Get some teflon tape and before reinstalling the fitting, wrap a bunch of teflon tape around the fitting. If you aren't familiar with teflon tape ask how to wrap a fitting properly.
Old Apr 27, 2007 | 08:19 AM
dfdon's Avatar
id try the silicon tape first put some one there should help alot if not go with rethreading
Old Apr 28, 2007 | 11:59 PM
t34me's Avatar
yeah, try the tape first before you start getting into all that.
Balto
Jul 10, 2014 11:24 AM
Dwack1992
Apr 8, 2013 04:05 PM
theRDRman
Nov 28, 2011 04:18 PM
mokijo2
Dec 27, 2007 12:11 AM
XHONDAX
Sep 20, 2006 03:19 PM
