grounding question...
I just want to make sure that I gonna do this right...
The yellow is the wire, the red dots are where I am gonna attach them. Is the image the right way to do it. I will be keeping the stock grounding points as well. http://i67.photobucket.com/albums/h2.../grounding.jpg |
RE: grounding question...
Anyone, anyone, Bueller, Bueller...
wow ^, that is some valve cover.
Whats wrong with it. Its much easier to keep clean with it painted.
Also, BUMP, I need to know if this is right.... |
i would at least keep a chassis ground from your valve cover. the others i would just run them to from the battery to chassis points and some to the motor
I don't know if there's really a "wrong way" to ground the engine. As long as the stock grounds are still being used, any extra ones you create are only going to add to their effectiveness.
I am in the midst of trying to update my grounds, but I am just pulling the old gay stock wires out and throwing some good high quality 4awg in there in it's place. I am too lazy to go to extremes. |
Windcalmers' civic is awesome! Baby blue is really nice.. you should paint the HONDA on the valve cover white, though.. and where did you get all those blue tubes? I should put my own engine picture up so I can see where to do it to my car... my battery is in a different place than your car..
Hey Windcalmer I hope you dont mind me piggybacking on your thread.... when someone answers you could someone draw those lines on my engine bay so I can get an idea as to where I should put the wires for my car?
http://i84.photobucket.com/albums/k9...y/CivClean.jpg |
ORIGINAL: TheMoogly Windcalmers' civic is awesome! Baby blue is really nice.. you should paint the HONDA on the valve cover white, though.. and where did you get all those blue tubes? I should put my own engine picture up so I can see where to do it to my car... my battery is in a different place than your car.. BTW, I like the new Sig. LOL |
hehe It's the one you made.. I am wanting to run better ground wires like you have in your picture up top... but my battery is in a different place so I was wondering if you could highlight where abouts I should connect the ground points...
Skateman reccommended me relocating my battery to the trunk but now I am hearing that it shouldnt be moved... so until then I dont mind spending a few bucks to ground my car better... thanks! And how many feet and connectors and size wire should I run? |
