Grounding Wires
Old Jun 19, 2008 | 03:06 PM
import tuner's Avatar
Default Grounding Wires
I had a few questions about grounding wires.
Do they just replace original wires?
Are they hard to install? (I don't think they would be, but tell me if i'm wrong)
Do you feel a difference in the way your car drives and/or runs?
Are they worth it?
Any information would be great.
Old Jun 19, 2008 | 03:22 PM
Default RE: Grounding Wires
1 - pretty much
2 - probably not
3 - f**k no
4 - only if the wires were free and someone installed them for you
there's only two scenarios I can see grounding wires doing anything useful (and even then, why spend how much on a ground wire kit? 4 gauge wire does the same d**m thing for 1/10 the price):
1) vehicles with large electrical demands that could actually use better grounds
2) cars with engine swaps
Old Jun 19, 2008 | 04:36 PM
dito. unless you have some added stereo stuff thats a decent size. your stock ground wires are fine. those large spider web ground wire things are just ugly as hell! and not needed.....
Old Jun 20, 2008 | 09:37 AM
I still have the stock sound system, but i'm thinking about getting new speakers and maybe a subwoofer.
Old Jun 20, 2008 | 01:56 PM
I honestly doubt that will push your electrical system to the limit where a ground wire kit would help much... if you haven't already bought one, I'd say save your money.
Old Jun 20, 2008 | 04:01 PM
I was debating whether to get one or not, but it doesn't sound like I need one so i will save the money. Thanks guys.
Old Jun 20, 2008 | 05:10 PM
save your cash and just buy some 4gauge amplifier wiring and some crimp conectors and make your own replacement ground wires...
Old Jun 20, 2008 | 05:39 PM
ej6buddy's Avatar
they're called braided wiring, and they're not useless, they use them in tractors and heavy duty equipment. i like mine, it looks good, and i had to replace it due to the oem bolt being striped out anyway.
Old Jun 20, 2008 | 07:50 PM
FlipHKD720's Avatar
you won't feel a difference in power, but my car started up ALOT easier, especially in winter, with new, larger ground wires. Headlights didn't dim during bass hitting either.
Old Jun 21, 2008 | 08:58 AM
ORIGINAL: addiction2bass
I was thinking about that... if he's putting in an amp/sub, he'll have some amp wiring left over most likely... just use what you have left over for DIY ground wires, and there you go... free ground wires.
