GSR vs Type-R engines
I was wondering if there is any benefit tostarting withthe B18C5rather than getting a B18C1 engine.My understanding is that theblocks are the same, the pistons are different (Type-R higher compression), and the head is different. What about getting a B18C1 and putting the Type-R pistons and cams in it? What if I decide touse aTC later? I'm thinking that the higher compression pistons would not be as suitable and would need to be changed, so the B18C1 would be better here; however, the pistons from the B18C1 may need to be changed as well to use with a TC. I'm not sure what the best compression ratio is for turbo, but I was guessing somewhere between 8:1 and 9:1, unless you go with low boost (around 7psi). Any help is appreciated. Thanks!
RE: GSR vs Type-R engines
The type r is so expensive that I just don't think it's worth the extra money. Plus 5-7 psi is all you are going to be able to run if you do turbo. I'd say GSR then decide if you want to go N/A or turbo. With a GSR 8-10 psi will be ok with a tune. The biggest plus is with the 1500-2000 dollars cheaper a GSR is you can make it more than the type r just with that money. If you know you want to turbo, you can save alot of money by going with a B18B.
changing a gsr motor to a ctr is near the cost of just buying the ctr motor.
I'm leaning toward using a TC, but what about the limitations of the B18B: weaker rod bolts, less reliable at higher RPM's, etc.? Are these only issues at higher RPM's, and not so much with the HP produced? Personally, I'd rather make the higher HP at a lower RPM (saves wear) if possible. Also, would the turbo B18B be okay with a VTEC head or should it stay non-VTEC? What about the B20B? Isn't it basically a bored-out B18B?
Increased piston speed increases wear as well...
How involved of a build are you looking to do? You seem to want an optimum set up. No one single B-series will give you that imo. I'm all about getting the most out of, well, anything though. You should see my bicycle. :D |
ORIGINAL: Kedawei Increased piston speed increases wear as well... How involved of a build are you looking to do? You seem to want an optimum set up. No one single B-series will give you that imo. I'm all about getting the most out of, well, anything though. You should see my bicycle. :D |
ORIGINAL: Sean Foster I'd love to be very fast in a straight line, but I'm more of a cornering fool, so track racing is what I am building for. |
ORIGINAL: mxs If you do it right you'll get a super smooth torque curve that's a ton of fun to drive :) |
build it yourself, it's more fun. [8D]
you'll have a hell of a time finding one in a junkyard though. |
