| guitar4ya |
Sep 29, 2008 10:33 PM |
H22 Cap and Rotor Replacement Problems Please Help!
Ok so hopefully this doesn't get too lengthy, but I just finished working on my friend's civic. He has a hatch with an H22 swap that was just done with a wire tuck. Anyways when you would punch it to accelerate fast, it would sputter as it was picking up speed. He just got the car so we went by autozone and got some stuff that just needed to be done and while we were there I asked the guy about it sputtering and he said check the cap and rotor. So I changed the cap and rotor and also changed the plugs. I couldn't get to the screw on the rotor without pulling the whole distributor so I did that and put the distributor back on with a new rotor and cap and plug all the wires back in to the corresponding plugs and go to start it and nothing. The starter does try and turn it over, but it doesn't turn over. It sputters some like it is trying to start but nothing. I checked the spark on each of the boots and all four were sparking fine. Then we checked the fuse box and one of the diodes was blown but the fusebox legend said it corresponded to accessory so I figured that wasn't causing the problem. What seemed like a simple few minute job turned into all night of us plugging away at it with nothing. Anyways any insight would be greatly appreciated. Thanks
