h22 or GSR?
Old Jul 11, 2006 | 08:42 PM
omgxitsxaxhatch's Avatar
Default h22 or GSR?
if you had a choice between h22 or GSR which would you choose and why?
and for those who hate h22 cuz you say you can only go in a straight line. i dont care cuz thats what i want to do.
Old Jul 11, 2006 | 09:48 PM
joe383's Avatar
Member
Default RE: h22 or GSR?
H22 because it's almost 25 cid bigger.
Old Jul 11, 2006 | 10:03 PM
Clean98EX's Avatar
love H22 civ's. i would totally do it. you see more B18's in civics than in tegs. then down the road throw a turbo or blower and just be wicked fast!! I would go for the F20B i think it is. the accord type r blue top H22.
Old Jul 11, 2006 | 10:29 PM
ef4life's Avatar
h22's can handle fine they aren't that much heavier than a gsr. besides when you add traction bars, and relocate the battery you are about the same as a b series on the front anyway.
but the bad thing about h22's is that they are mounted real low and only have about 3-4 inches ground clearance for the oil pan that is when the car is lowered slightly 1-2'
but i say h is the way to go. or go k series then own all.
Old Jul 11, 2006 | 10:37 PM
Clean98EX's Avatar
he's right the k series engine will rule all hondas one day.
Old Jul 12, 2006 | 08:58 AM
ORIGINAL: Clean98EX
yesh but its also 2k more expensive.
i wanted h22 cuz stock they have a lot of power. plus i love torque. and ya clearance will be hard. my car is extremely low. id have to lift it like 2 or 3 inches?
Old Jul 12, 2006 | 09:03 AM
plus i was looking and it seems like h22 is cheaper anyways. so thats where im going. ill have pictures when it happens.
Old Jul 12, 2006 | 03:02 PM
MY99SI's Avatar
i would gsr swap. you cannot turbo or spray a stock h22 with out internals done. the block and all the parts in side it are aluminum and dont like elevated cylinder pressure from a turbo or spray. b18c5 it and run 10 psi or a k swap like said up above would be alot better than that. most of the drag racers now days are using the k series motor.
Old Jul 12, 2006 | 03:38 PM
Marty's Avatar
ORIGINAL: MY99SI
I bet a stock H22 will hold as much power as a stock B18C1.
Old Jul 12, 2006 | 06:45 PM
MY99SI's Avatar
N/a i wouldnt doubt it but when u start adding boost problems start to arise with the h series
