H22A1 Swap
Old Jul 17, 2007 | 04:32 PM
hondacivic97's Avatar
Default H22A1 Swap
I have a 97 LX and am thinking of swapping the D16Y7 with the H22A1. Does this sound like a good idea? Eventually I'm trying to get a car that can compete in some races, but still be ok on the streets. I know a little bit about engine honing, and I'm wondering if once I get some more power, that would be a good idea too?
EDIT: Also, once I do the swap, when I'm looking for parts, what kind do I want? Stillparts that are listed for 96-00 LXs or something else? Thanks
Old Jul 17, 2007 | 04:46 PM
jeff948594's Avatar
Default RE: H22A1 Swap
that engine is from a prelude so you would need prelude parts for it, that is a mighty powerful motor though 200hp stock i beleive, it will be a good motor for you but it isnt the easiest swap ever.
Old Jul 17, 2007 | 04:51 PM
Alright, thanks for the quick answer. How much do shops charge for swaps usually? And anything about engine honing? Thanks again.
Old Jul 17, 2007 | 05:57 PM
PREKGSR's Avatar
i dont really know about prices but the h22 is a bitch to swap. B series are much easier and u can get almost as if not the same ammount of horspower plus they are a few pounds lighter than the H series. not much though
Old Jul 17, 2007 | 06:20 PM
ic892003's Avatar
for that swap id say around $1500, id go with a b-series tho, a lot simpler and cheaper to swap
Old Jul 17, 2007 | 06:42 PM
Ok, how much would you guess for the B series swap?
Old Jul 17, 2007 | 06:52 PM
ic892003's Avatar
maybe800 to $1000, do some more research, on what u want and what u need, u might want to do some extra work on the motor while its on the crane, maybe a new clutch, etc,,
Old Jul 17, 2007 | 07:05 PM
Alright, thanks for the help.
Old Jul 18, 2007 | 02:18 PM
Another question, is there any way to get a S2000 F series motor in a Civic?
Old Jul 18, 2007 | 03:04 PM
Skrapdoggydog's Avatar
the S2000 motor swap into a civic would be100 times harder to do than the H series swap.go with the H22A, it is a beast of a motor and is worth the extra money to swap. if you can't afford the H then go witha B18C.
