Has anyone seen the post in DIY Drivetrain about honda mini me??
This is my question Amanda is workin on a d15b7 will this write up work on my D15B2? if so are there any other details i need to look at??
RE: Has anyone seen the post in DIY Drivetrain about honda mini me??
the b7 and b2 share the same everything as far as the short block is concerned.........im assuming your vehicle is an 88-91 civic/crx dx/std/lx.........this will mean your running dpfi unless your car has been converted. but the headswap itself is the same between both engine. you will be able to use your current distributor unless you want to do an obd1 conversion(again assuming your using an 88-91 body)
