head gasket
hey what head gasket to i use for my d15b block with a y8 head 1.6
RE: head gasket
any D series gasket should work. it depends if you want low comp or high comp.
RE: head gasket
OEM. Unless you plan on boosting, then id go towards a thicker commetic aftermarket one to lower compression a tad.
RE: head gasket
ya for right now high compression will be good for right now but i will boost it later.where is the best and most resonable price and place to buy one at?
RE: head gasket
if you want high compression get a spoon head gasket. they raise compression by .45 points.
RE: head gasket
ok where do i get a spoon head gasket?
