Which head gasket for turbo'd D
Anybody know of good brands with high quality stuff and not too expensive prices, and a place to buy one?
RE: Which head gasket for turbo'd D
Nobody? I've heard good things about Fel-Pro. I've also heard that the OEM gasket should be fine. Please respond.
well uve got 2 options. Take off your valve cover, and install ARP headstuds and use the OEM gasket and ull be fine. Or remove the head of the motor (pain in the ass) get a thicker headgasket to lower compression, then install ARP headstuds. How many LBS of boost u going to run?
8. Yeah, it's a PITA to take off the head, but if it's necessary I can do it. Keep in mind the cars got 120k, and I'm not sure if it's been the same gasket the whole time. If I take the head off to replace the gasket, I might get it milled too. I've also heard good things about Cometic gaskets.
lots of guys have had 0 problems with stock head gaskets.......if u get those ARP studs......the head will not lift under boost and ull be fine for 8 lbs.
awesome, good advice pcupo, ARP studs it is.
BAM! There are my ARPs. Now i just gotta figure out how the head comes off so i can install them.
[IMG]local://upfiles/2201/61EA663611204C869D8C58227F180AB1.jpg[/IMG] |
oh crap, the head has to come off, damn, for some reason I thought you would replace the bolts holding the head on with APR's. Well, ok, let us know how it goes.
I think I read on turbod16 that some people installed them without taking off the head. Where'd you order yours from?
ORIGINAL: pcupo12 well uve got 2 options. Take off your valve cover, and install ARP headstuds and use the OEM gasket and ull be fine. Or remove the head of the motor (pain in the ass) get a thicker headgasket to lower compression, then install ARP headstuds. How many LBS of boost u going to run? |
