head id ?'s
i have a 92 hatch with d16z6 block and i was told it was that head. but i bought a new distributor because hte old was jimmied on, the bolt holes dont line up. i bought a new distributor for that motor but i have the same problem, the holes dont line up and i bought it for the d16z6. is there a way to id the head? its the single v-tech head and i have the numbes off the head i just cant find any place to id exactly wat head it is. any ideas? thank u for any help.
RE: head id ?'s
When I took apart my d15a2, I had trouble matching the distributor up to the camshaft. I found out that the distributor is only supposed to fit in 1 way, so I rotated my dist 180 degrees and it went on fine. See if this works for you?
RE: head id ?'s
the distibutor shaft lines up just the bolt holes dont. i want to get the right distributor so itll bolt in to all 3 holes instead of just2 like i have it rite now.
