head/mani/tb/intake/cams
sry about this post..i have some intake stuff in here but here it goes...my plan is to do a head swap to EX. After that is taken care of, will putting a new intake mani/skunk 2 TB and new intake + doing stage 1 (or 2?) cams do alot more for hp gains? Which mod would be better to do after the head swap first?
ALso w/the EX head swap- is a Vafc-2 from apexi all i need to make this work instead of re-flashing the ecu? |
RE: head/mani/tb/intake/cams
reflashing is cleaner because you dont have to splice into computer wires. but then again i do love the way my safc-2 looks ontop the steering column:D:D
ya i think ill go w/the vafc2 . but is that all that is needed?
If you do anything more than a stage 1 cam you will need an EMS. A VAFC2 will not cut it. Power gains... prolly not as much as you'd like, maybe 40 at the crank, real rough estimate.
Reflashing will be tough, have to find a custom guy, no shop will do an OBD2b reflash. |
yeah you would have to convert to obd1 to reflash
can i pull off stage 1 cams / vafc2? wat do i hav to do the reflash for, the stage 2 cams or wat?
