Head swap???
i have a 01 civic ex sohc vtec. i want to convert it to dohc vtec, is it possible?? i know with the older engines it was. its the d17a2. if it will work what head could i use. [&:]
RE: Head swap???
sorry didnt mean to attach that
RE: Head swap???
Not with a head swap. You would have to change out the whole motor. And if it makes you feel any better you couldn't do it with the older motors either.
RE: Head swap???
so there is nothing i could do except do a whole motor swap?
RE: Head swap???
if your go-n to do a swap get a B-series
RE: Head swap???
NEVER even CONSIDER putting a B into a 7th gen unless you are willing to custom build parts for the job and spend more money than it would cost to drop in a more powerful K. the only reason it should be done is for vanitys sake.
all Ds are SOHC, and its impossible to put a B head on a D block. you need to swap the whole engine. |
