HEADGASKET HELP
95 Civic DX Auto 1.5 L
My headgasket is gone. I started disassembling the engine to replace the head gasket. I removed the power steering pump, need advise how to remove the timing belt. I might replace the water pump since I am already there. Should I take precautions making sure cylinder number one is in TDC? Any advice will be greatly appreciated. Also any recommended merchant where to buy the head gasket? Thanks |
RE: HEADGASKET HELP
You can get a headgasket from places like autozone, pepboys, A&A, etc. You might wanna buy the whole gasket kit and replace valve cover gasket, spark plug seals,.... The whole kit runs for about 120 bucks.
RE: HEADGASKET HELP
I already have all the Gaskets,
Need some info on procedures and precautions |
