HElP! ??d15b overheating
hey guys and gals I have just done the water pump and thermostat as the water pump seal was broken and it was leaking ..
now its all done I over heat after driving for about 20 mins like over heat big time its steaming out into my overflow making a bubbling sound.. but if I put the heater on full blast its fine? any ideas I really need some help thanks awesome people :) cheers JDM first gen D15B 92 eg4 |
Try a new radiator cap ...bleed the cooling system... make sure cooling fan is coming on at the right temp (225ish).....if you still get bubbles in the overflow, time for a head gasket
I'm curious ya said its a JDM d15b I got the same swap. What timing belt and water pump did ya use? I read it has to come from a d15z1 cause that motor and the JDM both use a 103 tooth timing belt as well as the same water pump
