help to finish swap
Old Jan 2, 2006 | 10:59 AM
jwsimons's Avatar
Default help to finish swap
i need a little help with my b16 install. its going into ann '88 hatch, i need to know what axels to get, bu the wheel hubs are changed to an '91 si ? also which motor mounts wil install with the least amount of moding? and also, with the newer fuel injection, whats the easiest way to correct the wiring differences? (if there is an easy way?) thanks for any help!!!!!!!!!!
Old Jan 3, 2006 | 12:59 AM
Kappa22's Avatar
Default RE: help to finish swap
If it's a B16A1, it should drop in and bolt up to the stock mounts.
As for the axles, I believe any of the 90-93 Integra axles will work (I've only used the '91s though...). You have to take off the ring on the inner side of the hub bearing or they won't fit right.
Wiring-wise, you need an Si harness (or MPFI-converted stock harness) and you have to add four wires: VTEC activation, VTEC oil pressure, secondary O2 sensor, and knock sensor.
Old Jan 3, 2006 | 01:07 AM
Kappa22's Avatar
I should probably also warn you of a couple other things that I just remembered: Eventually, you're going to need a throttle cable and clutch cable from a '90-93 Integra, so you might want to start looking.
fivespeed
Oct 1, 2007 10:55 PM
my77stang
Jul 17, 2007 05:00 PM
riceburner700
Jan 29, 2007 09:09 AM
Tater
Nov 5, 2006 07:48 PM
JayMan
Jul 23, 2004 09:05 PM
