HELP PLEASE
Old Feb 4, 2007 | 05:14 PM
GDM200's Avatar
Default HELP PLEASE
tried to change my civic cam belt but cant undo one of the bolts on the bottom pulley [honda dealers have a tool for this]
any advice/tips etc
thankyou
Old Feb 4, 2007 | 05:17 PM
2slo4u's Avatar
Default RE: HELP PLEASE
I used an impact wrench.
Old Feb 4, 2007 | 05:39 PM
cpl rampage's Avatar
i just had to undo mine on an engine im rebuilding, i had to wedege a screwdriver/wrench in the transmission side, then put the socket on with a breaker bar, and use a huge pole over the end of the breaker bar, you will need to do it this way unless you have a really big impact wrench, you could have the dealership loosen it up for you, and then tighten it a bit so that the corosion is broken, and u could use a regular wrench
Old Feb 4, 2007 | 07:20 PM
99civicricer's Avatar
did this last weekend get two ball peen hammers set one of them of the nut and hit that one with the other one hard but not too hard. and then get an impact with a 17mm socket and it should come right off first try.
DontHateOnEG8
20
Sep 6, 2008 06:49 AM
dhdicato
Apr 14, 2008 07:25 PM
D16racerchick
Jan 3, 2008 05:15 PM
redridinhood
Oct 9, 2006 07:27 PM
Honda99Civic
Apr 20, 2006 10:13 PM
