Help PLEASE! SiR2 motor has no hp and delay on acceleration!
Old Jan 24, 2008 | 01:08 PM
ArmyMechBill's Avatar
Default RE: Help PLEASE! SiR2 motor has no hp and delay on acceleration!
Yes most likely you are off a tooth if u can check under the timing cover and see if it was off a tooth if not b ring it bak to the mechanic that fixed it to check.
Old Jan 25, 2008 | 12:43 PM
jamned's Avatar
Yeah, you're off a tooth. When you bring it back to the mechanic, you should also have him check out the catalytic. If it's messed up, it was him installing the belt wrong that caused that (for the most part, there might have been other small contributors like a bad o2 sensor).
burgernuds
Nov 6, 2008 06:07 AM
nightrider46
Dec 7, 2006 08:37 PM
zero one
Mar 6, 2006 03:57 AM
Punter
Dec 12, 2005 12:45 PM
sacicons
Jan 29, 2005 02:44 PM
