HG seperation
Old Sep 29, 2006 | 11:00 PM
t34me's Avatar
Default HG seperation
Real quick, engine re-assembly commences tommorow(sat) I have a 3 layer z6 and want to take it down to 2. Whats the best procedure for removing the rivets without damage?
Old Sep 30, 2006 | 05:37 PM
t34me's Avatar
Default RE: HG seperation
Are you serious, no one knows how to do this, or has done it themselves?
Old Sep 30, 2006 | 09:49 PM
HARI.'s Avatar
i wouldn't do it......Do it if you want, but consider the fact that the middle layer has staggered coolant orifices to help evenly cool the head and block.
Old Oct 1, 2006 | 08:57 AM
t34me's Avatar
so which layer out of the 2 on a Y8 has this orfice?
Old Oct 1, 2006 | 12:54 PM
HARI.'s Avatar
the middle one
Old Oct 1, 2006 | 04:41 PM
t34me's Avatar
Y8 is 2 layer right? so there would be no middle. Either way fine, can i use the middle and one of the metal layers? How do i remove the rivets
Old Oct 1, 2006 | 05:22 PM
Marty's Avatar
Why are you wanting to do this, the most you will be able to change compression is around .3 points and that is hardly worth altering you head gasket to acheive.
Old Oct 1, 2006 | 07:16 PM
t34me's Avatar
i just wanted to squeeze as much compression out as possible, but if its not worth it, screw it
