how can i get a compresion test??
Hey guys hoy the heck can i run a copressio ntest to my car?? though i was wondering my engine has 175.000 mileage if y do and engine reparation (as i said) i mean replacing pistons, hihg compression, rods, valves you know everything inside it .. the jod cost like 500 bucks or more.. if i do that to my engine i have guarantedd that it can last 200km more??? or it will die the same soon if i do that job or not??
RE: how can i get a compresion test??
to do a compression test you have to have a compression gauge with the rubber hose you screw into a spark plug hole...
step by step 1. pull out all spark plug wires and set them on top engine 2. pull out all spark plugs 3. screw gauge into spark plug hole #1 4. crank car for about 5 seconds 5. read gauge and write number down 6. screw gauge into spark plug hole #2 7. crank car for about 5 seconds 8. read gauge and write number down 9. screw gauge into spark plug hole #3 10. crank car for about 5 seconds 11. read gauge and write number down 12. screw gauge into spark plug hole #4 13. crank car for about 5 seconds 14. read gauge and write number down all the numbers should be no farther apart then 10psi hope this helps |
Please remember to disable the ignition coil by pulling the ECU fuse. I just replaced a coil that I fried because I didn't keep the ignition from firing while doing a compression test.
https://www.hondacivicforum.com/m_24..._1/key_/tm.htm You'll also get more repeatable and universal numbers if you hold the throttle wide open while cranking. In addition to a compression test to tell you about the top end, connecting a mechanical oil pressure gauge will give you some insight to the condition of the bottom end. |
ORIGINAL: riceburner700 to do a compression test you have to have a compression gauge with the rubber hose you screw into a spark plug hole... step by step 1. pull out all spark plug wires and set them on top engine 2. pull out all spark plugs 3. screw gauge into spark plug hole #1 4. crank car for about 5 seconds 5. read gauge and write number down 6. screw gauge into spark plug hole #2 7. crank car for about 5 seconds 8. read gauge and write number down 9. screw gauge into spark plug hole #3 10. crank car for about 5 seconds 11. read gauge and write number down 12. screw gauge into spark plug hole #4 13. crank car for about 5 seconds 14. read gauge and write number down all the numbers should be no farther apart then 10psi hope this helps |
ORIGINAL: HaZe89 Hey guys hoy the heck can i run a copressio ntest to my car?? though i was wondering my engine has 175.000 mileage if y do and engine reparation (as i said) i mean replacing pistons, hihg compression, rods, valves you know everything inside it .. the jod cost like 500 bucks or more.. if i do that to my engine i have guarantedd that it can last 200km more??? or it will die the same soon if i do that job or not?? |
