How do H22A's NA tune?
How well do H22A's NA tune, id like to know as im considering a swap away from my B16?
an will someone please tell me, i have had no luck on any forums or through hours and hours of google searching, what do i need to buy to make a H22 conversion happen for my EG6? |
RE: How do H22A's NA tune?
you need mounts, axles, ecu, shifter, cable linkage. you could keep the B16 tranny and do a H2B swap.
that h2b swap parts cost between 900-1200 i think. there are 2 major kits out there. one is a replacement custom flywheel, the other is an OEM flywheel spacer i think.
so is the H2B hybrid worth the cost?
axles....from a prelude? also, is it true that H22a EGs have atrocious handling? |
the H series trans arent that strong (so i've heard) plus the gearing of the b series trans is better at keeping it in vtec between shifts
