how many "mm" is my JDM b16a intake manifold?
I have a 95 honda delsol DOHC vtec JDM B16a I was wondering how many mm is my IM. cuz i seen intakes on ebay that are 65mm but i want to make sure that mine is not the same size. And what are the gains of putting a high flow IM ?
RE: how many "mm" is my JDM b16a intake manifold?
What do you mean you want to make sure yours insn't the same size? The purpose of an intake manifold is to be less restrictive, and let more air-flow in to the motor. If you're replacing just the manifold with out any other mods, Id say maybe 7-10hp at the crank.
i kno the bigger the opening the more air. but i was tring to say i want a 65mm opening but if my stock IM is the same why should i buy the new one. But i think stock is like 60mm but i'm not sure, thats y i'm not buying the other IM
what brand is the other one?
skunk2 or OBX
I see, well Im almost a 100% sure that the after market manifold opening would be bigger, and also, aftermaret manifolds are designed to be less restrictive than stock either way.
yeah, go aftermarket.
